Check the fuel pump, relay and fuse. Can you use a stethoscope and hear the injectors firing?
When you replaced the crank sensor you mentioned fraying? Are the wires back to the ECU in good condition/still attached? (could have gotten yanked out if it got sucked into a pulley)
And when you put the new sensor in, how close is it to the tone ring?
