Old 10-01-2009, 12:09 PM   #16
djbmw
Your Ride: 94 318is, 98 328is
Repair instead of Replace
Great info Amanda!
For anyone with an OBDI E36 heater controls are the dial types like above,.. you can REPAIR your resistor pack! The pack has a Thermal Fuse at the very end of it that will blow open if the unit overheats at 240 degrees Celcius (you can see it in Amandas pictures - its the silver thing at the end of the green coated fuses). This is why most of them fail. The fuse is: pat microtemp 4468a ckacn 240 degree celcius and costs no more then $2 at your local electronics surplus store.
WARNING: if you try to solder this fuse understand that it will open at 240 degrees celcius,.. so use cold solder paste or watch your iron temperature (use heat sinks when soldering).
** To test that the thermal fuse is the culprit, just jump/bypass the thermal fuse with a paperclip/wire and hook it up for a few seconds. If you get all of the functions then you know its the thermal fuse!
