Old 09-05-2009, 09:18 AM   #2
3050rpm
3050rpm's Avatar
A very quick response... Make sure the plugs are factory spec (I believe either Bosch or NGK), DON'T put in anything else, whether platinum, gold, silver, uranium, or whatever. If there's oil in the spark plug wells, sop it up, and change the valve cover gasket. Sounds as if this car has been overdue for some other maintenance as well, but these suggestions are a start.
