Old 08-22-2009, 05:22 PM   #1
Bryan
Bryan's Avatar
Your Ride: 1998 328i + 1973 2002
e36 will not start
my 1998 328 will crank over but will not start error code p1747 any suggestions?I tried using the flash codes but now my check engine light will not even come on at all!! It seems like there is nothing working but I manually checked the fuel pump and it does work , it's just not getting any juice through the ignition. All the fuses are ok , the relays work when they are supplied voltage but will not work when I try to start the car, it just cranks with no result!! NO-JOY!!!!
