Old 07-21-2009, 11:34 PM   #23
shankster77
Your Ride: 1993 318
Yeah those cylinders are not holding much air in at all. It is leaking right out with the valves closed, back out through the oil it seems. It seems like it is going right past the rings. I had poured a little sea foam down the cylinders just in case they were stuck with a little gunk and then when the pressurized air came through it vaporized the sea foam back up through the engine. pretty sure thats what was happening.
