Thread: I hate leaks!!!
Old 07-20-2009, 10:49 PM   #1
sandersnsandy
sandersnsandy's Avatar
Your Ride: 1997 740i
I hate leaks!!!
As I said in my last post the unit is leaking at the top fitting on the steering box.The fitting/banjo bolt used an aluminum washer to seal the banjo bolt to the steering box. I have tried copper washers,aluminum washers and nylon washers.None of these have been able to seal the fitting. Could I be applying to much torque? Or maybe not enough. I sure dont want to snap the banjo bolt off in the steering box.Does anyone know what the torque should be? and is there a special washer that I should be using. the ones I used were standard aluminum washers from the parts store.
