This is my first post on here so please excuse any lack of posting knowledge. Ok I have a 89 325is that I just recently swapped motors in, I added the 2.7L eta Block and Kept the "I" Top end on it. The car is mostly stock aside from a Jet chip installed in the Ecu and Air intake. The problem I am having is that the car will not start, If I were to use starting fluid it will run as long as the fluid lasts. The fuel pump seems to be working properly with good pressure as far as I can tell. I have checked relay's and fuses, but it seems to be the injectors not letting the fuel into the cylinders. Is there anything I should test or check to fix this problem? I would greatly appreciate it as it is getting very frustrating.
Thanks,
Josh
