Old 07-10-2009, 05:12 PM   #4
David Mc
David Mc's Avatar
Your Ride: 1998 e36 328i
Assuming that you have replaced the transmission fluid with the correct fluid type and have filled it as per this guide http://www.pelicanparts.com/bmw/tech...Fluid_Auto.htm
the most likely cause is a stuck shift solenoid. Double check that the cause is not air in the cooling system that is preventing the temperature sensor signalling he DME/EGS that the engine has warmed up as this is also a possibility.
