Old 06-03-2009, 08:56 AM   #1
chaswr7
Your Ride: 2000 M Roadster
Rear end Noise and Shifter issue
I just bought a 2000 M Roadster. I have two questions:
1. There is a click/squeak (not sure how else to describe it) coming from what sounds the like the rear driver side while driving. It stops when braking. I lifted the rear end and turned the wheel by hand. The wheel spins freely buy on each revolution there is a spot where I can feel some slight drag from something rubbing i would assume. My guess is either a warped rotor or wheel bearing. I dont feel anything in the handling under acceleration, braking, or cornering.
2. Yesterday after driving around for a bit it became pretty much impossible to put the car into gear if not moving. If i was rolling even slightly i could put it in gear but it was still difficult. While driving through town I did not have any problems. This morning when i left for work however it shifted just fine, even at a dead stop.
Any help will be much appreciated. I will try to answer any questions as best as i can.
