Check engine light is often due to vacuum leak. Check for a leak at the vacuum pipes, that go around the intake manifold, crankcase ventilation, intake air booth. Also check the intake manifold gaskets and throttle body gasket. You can spray throttle body cleaner on those with the car at idle, you will hear a change in idle if there is a leak.
1993 (build 05) 525i auto trans 215K miles
