$8000 is about right for that car, it isn't low at all, it may even be a bit high, even if the car is in good condition.
peter- borrow a compression tester from Brad, and we can test the compression of the cylinders when we go down there, that will tell you if the head gasket is good and stuff. we should also check the rear shock towers for stress.
