Not clear on your description- does it crank each time, even when it doesn't start, or when it doesn't start it also doesn't crank? The times when it doesn't start, is it after a long period of not running, such as overnight? How does it run when it does start, smoothly or erratically? I wonder if you might have a faulty fuel pump relay (when was the last time the fuel filter was changed?) or leaky fuel injectors.
