Old 05-11-2008, 11:39 AM   #2
elsabor67
elsabor67's Avatar
Rate My Car: 7 / 284
It's easy but...
1. You have to figure out what cables (+ & -)go to what speakers and...
2. Are you using the factory radio?
Reason I am asking is because the factory radio has 1 (2+ & 2-)set of wires to run 2 speakers. If you run all 4 speakers then you run into the risk of pushing a lower Ohm load to the speakers (2 ohms instead of 4) and can also damage the factory radio after prolonged use because the radio was not meant to operate at that load. Check well before you do.
How do I spell relief??
AUTOBAHNNNNNNNNN
