The check control panel only lets you know of things like the fluids and any burnt lights. That is wierd that it won't throw you a code. Do you do it with the key in the "on" position (Not trying to insult your intelligence) without starting the car? It won't even display the "1444" everything is good code? If it's not even coming on change your bulb on the cluster then try it again cause that sounds wierd. Good luck.
