Old 05-09-2008, 01:46 PM   #2
3050rpm
3050rpm's Avatar
You might not have to go to all that trouble, this was a common problem with early E36s. This is what I was told by the technician at the dealer, and it's worked for me. Find the appropriate fuse for the indicator light on the dash (I'm not sure which one it is, maybe #21, but check) and remove it completely for 10 minutes. Reinsert and then see if your gauge starts working correctly. The fuse itself may look just fine, but just remove it for the period of time and take it from there. I hope that works for you.
