Old 04-02-2009, 01:33 AM   #1
kazamali
Your Ride: 99 M3
Need diagnosing help on 99 M3 E36, Rough Idle, Cold Start Issues
Hi Everyone,
I'm posting to a number of forum sites in hopes of getting some good advice on my issues(I apologize if you've seen this already):
First, the data:
-99 M3 E36 Coupe, Manual tranny
-99k miles
-Active Autowerke Stage 2 Twinscrew Supercharger (AA intake, stock exhaust)
-All maint/SC work is DIY
-Inspections done on time
-No negative history on the car at all
-No major sensor/equipment replacement (except for MAF)
History:
-Bought the car in '02 (36k miles)
-Supercharged it in '06 (80k miles)
-Ran perfect before SC
-Ran perfect WITH SC for 2+ years
(except the occasional <every few weeks> 1188/1189 CODE with no visible performance effects. just reset it, no biggie)
-Dec '08, Car refused to start/hold idle one nite after a short trip and was dumping mass amounts of fuel, blk smoke/soot out of the exhaust(had to disconnect MAF to limp home)
-tried starting it a few times after that before confirming a MAF issue
-replaced MAF(AA uses an e39 MAF for the higher flow), no change
-replaced Active's calibrator unit (connects between MAF and DME to cap E39 MAF voltage to DME), car finally started
Problems(since above steps):
-On cold start, the engine shudders violently for the first 20-30 seconds, like it can barely hold idle (basically you can hear the clanging of the exhaust because the engine is so out of balance
-if I try to back the car out of the garage in the first minute or two, the idle dives as soon as I hit the gas (like the fuel or air is literally cut when hitting the pedal)
-once car warms for a couple of minutes, idle smooths out, but it feels like the engine "skips" a beat (hard to explain, but it's like a minute hiccup at idle every 10-15 seconds
-if I take a short trip (say a mile or two), stop the engine for a few minutes, then start it again, the idle starts to "hunt" or bounce up and down and then drives rough (like choking for a few minutes)
-on longer trips at freeway speeds, I can feel the engine "skip a beat"
-Hard acceleration can "hiccup" as I hit the higher RPM's (but this problem is not always consistent)
-Engine codes thrown CONSTANTLY: 1188/1189 (fuel control bank1/2 sensor 1), 0170/0173 (fuel trim malf. bank1/2)
Before I nosedive into buying the wrong items (ICV, ECT, O2 sensors-which probably need to be replaced anyway), I wanted to see if all of these issues together point to a smoking gun and can possibly help someone else. Yes, my car is at almost 100k miles and yes some component degradation might have been accelerated due to the supercharger, but I'm hoping someone out there has seen this and thru their own troubleshooting have found the solution. I've walked thru the whole vacuum/intake system with carb cleaner to find a leak, but no joy.
I'm not a beginner mechanic(I put in the SC without any issue), but I'm also not heavily exposed to many varied situations like a pro or forum folks. I've scoured many forums and have tried some non-intrusive stuff thus far. I know this can be the "holy grail" of troubleshooting, so any help would be much appreciated.
Thanks!
-Kazam
