Old 03-05-2009, 05:56 PM   #2
motorwerks
Title: Sitting in Time out
Rate My Car: 160 / 337
Your Ride: '97 328i
You probably need to change your microfilter. A clogged microfilter won't let the air through to blow out of the vents.
Be sure your spark plugs, air filter, fuel filter are up to date, and oil change are all up to date. If you don't know, then just change them. If it's an auto change the trans fluid, and filter. Consider changing the rear diff. fluid.
Become familiar with www.bimmerdiy.com/e36 www.pelicanparts.com www.realoem.com
