If you are running aftermarket wheels they may need a hub-centric ring to fit snuggly on tha hub... if you are running stock wheels then jus disreguard this but yeah start with wheel balance and then check the suspension components like ball joints and Control arm bushings which can cause similar symtoms as u were describing..
