Old 12-08-2008, 07:51 PM   #8
delmarco
delmarco's Avatar
Rate My Car: 228 / 340
Your Ride: 2001 330i
5. Begin drilling anchor holes for screws for the LED chip. This is optional as you can use glue to anchor the chip or a similar adhesive like Velcro. Remove the Slider Cup Holder trim; it easily pops right off from its rails. Drill two holes and use small two small screws that will hold the chip in place. It is really tight in there and if you have big hands this is a good time to have your girlfriend, wife or a small child help you with the screws. Either way glue or similar adhesive (like using a Velcro kit to hold it in place) will work the same and be easier.
6. Splice the LED chip + and - wires to your power and ground leads. I used a clip in/clip out connector so I can easily remove the LED chip from the wires if I need to change the LED, remove the armrest or remove the DIY from the car in the future. You can use heat shrink, solder etc....
Just keep it safe and clean. Also feel free to use inline fuses as well. I did not use them for any of my Console LED DIYs because the power sources that I tapped into already have safety fuses. Also genuine LEDs consume little power and usually burn cold, unlike the hot, energy-consuming filament bulbs used thru out our cars). The LEDs that are installed in these DIYs are water resistant and fire safe. That said if you have any further safety concerns or intricate questions about LED bulbs or the basic wiring used in these DIY please consult an electrician before attempting them.
7. When the LED chip is set and all the wiring is complete test your set up at the car's battery or any 12V source. If everything works then you can replace the rear cover making sure the 8 clips all click back in. Be sure to leave some extra length of wire in the sliding space behind the console storage or you will find the short wiring doesn't allow the storage tray to slide all the way out. At this point make sure that the tray, as well as the cup holder slider move freely without any blockage from your LED Chip or wiring.
