If the red led is lighting on both of the fobs when you press the button then they are probably OK . The alarm might have been disconnected by the previous owner though (maybe to install an after market alarm?)- it would be worth checking to see if the unit is connected. The alarm unit is located behind the glove box so to check it you would need to remove it.
I assume that you have checked the fuses?
