Originally Posted by theeuroguy
I just looked at a wiring diagram and there is nothing tricky about that system, it recieves its power directly from the switch and you have that..What I would be looking for is the physical connection point between the contact strip and the window?, solder connection?.
every strip has power, so my guess is that wire FROM the window lost its connection...Yesterday I read somwhere that wire should be connected to the ground (G300) somwhere behind the seats.....but Im still not qute sure where is that..
