Originally Posted by mzbmw325i
Start with the basics, check your fuses first, does the defogger button light up when you push it on, might be bad as well?
yes button lights up....fuses are OK ...
When I take electrical tester and connect one end to window wires, and the other end to metal where back door locks down, electric tester light up..
So I guess that wire from the window that is connected to the ground lost contact somwhere, but I cant see where that wire goes after where is connected to the window.
