Old 10-10-2008, 10:05 AM   #8
C Sean Watts
Name: C Sean Watts
Your Ride: 1997 328is and others
Honestly,
Originally Posted by donleycott View Post
The engine does not idle smoothly, it seems to idle at a lower speed than it used to.
Where is this solenoid, what does BMW call it?
Thank for helping
Pat
With no more than a code reader, it will be very difficult to troubleshoot a poor idle. In order to glean any good info from a forum, be as specific as possible and provide info like; year, engine, miles, exact conditions when the problem occurs, cold, warm, hot, what makes it better, what makes it worse, what you have checked/tested, or not, what corrective action you made, etc.
You will tend to get better answers that way. What you describe now sounds like a vacuum leak.
There are multiple posts that go something like, "I replaced part 'X' with a known good replacement and the problem didn't go away."
Later the 'known good replacement' was replaced with a new dealer part that fixed the problem. So it isn't hard to see fault in how to fix something in the forum?
As for finding it on the engine, a good, high quality manual or realoem.com will have pictures - a picture is worth a thousand words.
Reset the code memory and see how long it takes to come back.
