Old 03-26-2008, 07:21 PM   #13
junkdrawer
junkdrawer's Avatar
what if you dont get the cabs installed in 30 minutes? if I have a shop do them I wont be able to get them on soon enough. what will happen they will cease in the wrong place?
This may be based on the fact that bmw recommends a special lubricant, that has a bmw part number, which dries up in 30 minutes. so if you put them on slightly off from where they should be they can adjust once mounted on the car and set down to seat them properly.
now is that lube necessary? you guys used soapy water? what else?
do i need to sand the control arms if they are new or is that just for old ones?
is this the only reason it has to be done so quickly?
I am getting ready to redo my whole front suspension and I need to know about this before I get started.
just got this beautiful 95 325i and all It needs is the front end worked on and a high pressure p/s hose which aleaks very slow.
thanks in advance
junkdrawer
1995 325i with motorsport body package
