do you have any brake pad left? Or is it worn down to the wear indicators(itll make a sound)
check your brake fluid level?
check the ABS fuse/relay(not sure which one the ABS runs on)
Are the brakes still working?
When you depress the pedal to stop does the pedal go farther then it used it?
We all get the urge...Saturday early morning...nothing to do till noon...
BMW FTW
