Thread: Vacuum problem
Old 03-23-2008, 01:38 PM   #6
m3flyer
m3flyer's Avatar
Rate My Car: 3 / 340
Your Ride: 1) Alpinweiss 1989 M3 2) Diamondswartz 1989 M3
Thumbs up Ding !!
Originally Posted by johnnybayonne View Post
If you had a vacuum problem with the brakes & brake booster, you would have a stiff pedal or find it difficult to press down on the brake pedal! Squishy brakes sounds like air in the brake system or bad master cylinder!
http://autorepair.about.com/od/troub...s_brakes_2.htm
http://autorepair.about.com/od/troub...s_brakes_4.htm
2nd.
Johnny is correct.
Although loss of the booster entirely may result in weak pedal as well.
Also... check the master cylnder.
Try a synthetic Dot4/5 fluid and flush 'til the bubbles disappear.
Carpe Diem
