Thread: powertrain swap
Old 03-16-2008, 07:53 PM   #4
johnnybayonne
johnnybayonne's Avatar
Rate My Car: 252 / 340
Your Ride: 1997 328i
Originally Posted by Antiburn View Post
You will need to change the front subframe, drive shaft, instrument cluster, and possibly redrill rear trans mounts but it might fit. You would want to use the same diff. Auto's tend to have a better gear ratio then manuals which you can find out at realoem.com what the ratios are.
+1
http://www.realoem.com/bmw/select.do
