Old 03-13-2008, 12:33 AM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 131 / 246
Your Ride: ^^
Originally Posted by smokeewon View Post
Ops I did forget one tip. When putting the strap back on stick your screwdriver into one of the holes in the upper strap and match it to one on the lower strap. Then use that leverage to tighten the strap as you guide the plastic pin back into its hole. Ah..., the plastic strap is on the cover. Glad I thought of that..., the metal clip on the motor can be released by simply taping the raised portion of the clip. There is a hole in that part of the clip. You are smashing this down and expanding the diameter of the clip. When you are ready to reinstall the clip just reform the clip back to its former shape and clip it back on. It is easier said than done though.
dam man.
assuming uve done this before.
Next time(for anything) take pictures and do a write up if you have the time.
