Old 03-10-2008, 01:40 AM   #10
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 131 / 246
Your Ride: ^^
Originally Posted by Exilion View Post
That sucks. If you can find a place and time to work on it, I'd try taking apart the door and trying to see how it's working/not working. However since I don't have much experience with your car I'll just serve as a bump for your thread. Hopefully it works out.
heh.
unless you have very good patience i dont recomend this. remeber you have side airbags. which makes it that much more complicated. and you cannot remove the door lock without removing the window regulator, which basically means the entire door is coming apart.
then if you forget something in the door, or a piece of plastic falls in there..itll rattle like none other.
ive been through this, took my 330's door apart like 5 times. and then i said fuck it and had it done professionally.
