Originally Posted by nick_318is
Slotted or cross drilled rotors are overkill for most people, if you are not at the track I personally see no reason to have them they will not help you stop any faster and your probably not getting the brakes hot enough long enough for any real benefit. A cross drilled rotor you run a higher chance of cracking the disc and you need to get a real one that has chamfered holes not a cheapy that was drilled out so they could sell them for more. I would be more interested in a slotted rotor then a drilled rotor for the street, but i would probably just go with a nice brembo blank and save some money. If you want them for looks its all a matter of personal choice.
+1 on Brembo blanks if you are not tracking or doing extensive 5 hr. mountain runs.
As far as exhaust, I would hit youtube and try to find some clips that show them installed and give you sound bites. There are a lot of choices out there, do your research. Oh wait.... its Johnny, there will be plenty of research. You seem to make consistently educated and tasteful decisions. I am now eager to potentially copy you.
