Originally Posted by peterkdenny
Welcome. do you know if there is an easy way to fix a section of sagging ceiling fabric? without taking it off? thanks!
The bad news is....there is no way to fix a sagging headliner. The headlining material is a foamback material. The foam begins to turn into dust which make the cloth material sag. If anyone tries to repair it, you will end up having a bigger problem. Give me an idea of where you are located and I will see if I know of a good trim shop in your area that can help you at a reasonable price.
Thanks
John
