yea the hose should fit right on, my manifold is different than yours but it should be ok. yes its def good to use as both preventative measure and as cleanup and it may straighten out a rough idle, etc. a couple tips though.. if u want to do the job right, use a FULL can into the manifold and it says to let it sit for 15 minutes.. but the longer the better. ill let mine sit for like 4 hours.(1st time i let it sit for 15 minutes and got next to no smoke comin out, meaning it didnt clean very much out. next time i did it for a few hours and holy shit did it smoke) use another FULL can on a FULL tank of gas and if you wanna run it in the crankcase just add it a couple days or a week before you change the oil. also u may need a friend to man the throttle because if u pour it in too fast it'll wanna stall out. good luck and enjoy smokin out the neighborhood haha its really quite a sight
