Old 01-16-2008, 06:44 PM   #1
chris2005
Your Ride: 95 328 coupe
95 e36 328 ABS Light on
Hi all,
I have a 95 328 with the abs light on,
I have got all the information off autodata and have checked all the resistances and voltages, Relays, modulater,brake pedal switch,speed sensors,and power at the ecu everything is as it says it should be,
The only thing that is not right is when I spin the wheels at 60 rpm approx there is no voltage coming from any of the wheel sensors but the ohms readings are fine,Autodata say i should be getting 0.3v with the meter on alternating current setting but there is nothing happening.
thanks chris.
