Old 01-07-2008, 06:32 PM   #3
scott733i
Your Ride: 1983 733i
Check out the pics.....
SEVERE wheel hop....wet road, behind time and tried to hurry and get going once the light turned green....rearend hopped violently and this was the result. All in a matter of seconds. Limped it back home (about 2 miles). Check out the severe camber. Differential is only about 1 inch off the ground. Rubbed the pavement a few times on the way.
Found a cover at a local salvage yard....$25 with the rubber mount. Took me 15 minutes to remove it. Thanks for the responses!!
