Old 01-06-2008, 12:53 PM   #6
JThelen
Originally Posted by gannando View Post
I have a 1997 328is thats overheating! I've changed the fan clutch, thermostat,water pump. It continues to overheat. There is light white smoke coming out of muffler. Could it be the head gasket? help I'm at my wits end!
I had a similar issue with a 1994 325i. I replaced the radiator, thermostat, with no resolution. Turned out it was a head gasket issue, and the length of time cracked the block as well. Hopefully your problem isn't that bad, but it's quite possible the gasket is blown, especially if there's a coolant smell in the exhaust.
