Old 12-19-2007, 02:46 PM   #1
Nickmtzr
Your Ride: 1995 318i E36/M42 1/95
Car won't start No electric to the fuel Pump
So, my car died. Ive replaced the fuel pump, fuel filter, Mass airflow boot (was bad to begin with), and DME (used). I read somewhere that if i wasn't receiving 12v to pin 85 on the DME relay switch that i had a bad DME. Questoin is, did i get another bad DME? Or, do i need to reprogram the DME to work with the car. All this time i fugured i would just swap the DME and be done with it. I hadn't replaced the DME relay or the fuel pump relay because I found that I wasnt getting the proper voltage to the DME relay Pin 85. Im getting .30v - .36v when the key is in position #2 and when I have someone turn the key to start it. I may just replace them anyway.
Testing I have done.
-12V to the fuel pump, it works i hear it buz.
-Sprayed starter fluid in the intake, the car runs as long as there is fluid.
-Car turns over just fine, not getting any gas to the car.
-Tried a Pedal Stop i got "3214" I didn't find the code anywhere.
-Disconnected the battery completely, touched - and + to drain any electricity. (no luck)
Something I need to try is swapping the chip from the old DME to the new(used) one. I also want to check if there might be a wiring problem between the DME relay and the DME. I would need some insight on how to do this if its even possible.
Any insight on this would be helpful.
Thank you
**********DME INFO***********
0 261 203 282
318i/is/Ti
E36
M42/B18 DISA2
1/95-->
0 261 203 282
Bosch Motronic M1.7.2 w/ EWS-II
