Old 12-07-2007, 09:33 PM   #3
TECH
Your Ride: Sick cars.
Yep, check faults. A clutch isn't going to make the engine run poorly. Something simple, check both battery terminal connections and the ground to the body-make sure everything is tight. Make sure the jump point under the hood isn't burned or loose.
