Old 12-05-2007, 01:25 AM   #6
forrestohyea
Your Ride: 2000 e46
Its weird because the speedometer works great Is there another way to translate the code so I could be more specific on the exact problem? It says "vehicle speed sensor A " Does the "A" stand for anything? Maybe a wheel? Tomorrow I will swap wheel sensors, clean the hub inside the sensor holes, check the connections on the DSC unit, and check the error code for a change. Also another note - my wheel sensors are magnetic looking, there is no wheel on the sensor.
