Im not sure how you guys interpret the fault codes but with a fuel trim fault I would check the intake boot off the throttel body. Theres a small off shoot that goes to your idle air valve and they always dry and crack and cause unmetered air leaks expecicaly on older car like yours.
As for your cam sensors, if your doing one, do the other. They sometimes go bad in pairs and are easy to do.
