Wow,
i did this so long ago. Installion shouldn't cost more than $=$200. The part itself is about $200.
Everything parts and labour should be about $500.
The e46 and e90 rear shade should fit on the e36.
Go the
www.realoem.com to find the part numbers and prices.
Or you can go cheaper and order the manual one.
and just install it wih screws and clips.
I bought mine off eBay...Do a search on eBay for "BMW rear shade"
and a few of these shouldcome up.
Here is one...
http://cgi.ebay.com/ebaymotors/BMW-R...spagenameZWD1V
Just get the measurements and make sure it fits your car. 2 door E36s are wider than 4 door E36s as well so keep that in mind.
Good Luck,
Del.
Originally Posted by Georgeskada
hi i see your post about manual rear shade for bmw e36 first quest:
does the rear electrique shade for bmw e46 can be fit it to bmw e36?
2.please can you write to me a write ups how i install or retrofit the electrique rear shade on bmw e36? and if you can't please with pictures.
3.and how mutch it will cost me?
4.Please can you give me the correct part numnber that schould i buy?
thank you in advance;
Georges kada
