Old 10-30-2007, 12:30 AM   #9
SHAHAB323IS
SHAHAB323IS's Avatar
Title: Professional Noob
Your Ride: 1998 323is
Originally Posted by Numark318i View Post
...wow surpises no one has said this yet.
Lift the arm off of the shocks weight. I guess the only way would be with the rotor? I know when i was removing my tie rods in lifted the assembly with a jack via the control arm to loosen the tension on the tie rod. Couldnt you do the same with the control arm? Im sure the ball joint isnt designed to come out at that angle?
what you're saying isn't necessary but I should have said this, remove the inner ball joint first if possible, then use that tie-rod puller
