Old 10-24-2007, 09:56 AM   #7
Elliott
Your Ride: E46, 325i ,2001 model
Not engaging
Originally Posted by m3flyer View Post
Auto trans. and Standard trans both have clutches... The auto has a clutch pack internal
...if it is an auto it may be the neutral safety switch that has become inoperative and is causing the problem.
...if it is a standard it may be the throw out bearing is no longer allowing the clutch to engage. Do you hear a constant whirring noise when the clutch is not depressed ?
Sorry for your trouble... Hope it is solved without too much fuss.
I hear a constant whirring noise when the clutch is pressed !Oh thats a manual box!
