Originally Posted by stevo
sounds like the clutch is not working, what does the clutch pedal feel like when you press it to the floor? It is hydraulic clutch on your car so it may well need bleeding or there may be a hydraulic failure or a component of your clutch may have failed, thrust bearing or pressure plate.
Yeah i suppose cos i took it to service center and found that the clutch kit is gone.Let me just replace the Clucth kit ones.
