Old 10-23-2007, 06:50 PM   #5
m3flyer
m3flyer's Avatar
Rate My Car: 1 / 246
Your Ride: 1) Alpinweiss 1989 M3 2) Diamondswartz 1989 M3
Exclamation Afaik...
Originally Posted by Elliott View Post
Hi guys i do have a problem my car (E46 ,2001,325i) is failing to engage it only engages when the engine is not running.This just started all of a sudden.What could be the problem?Please help guys...some were telling me that it could be the clutch kit.
Auto trans. and Standard trans both have clutches... The auto has a clutch pack internal
...if it is an auto it may be the neutral safety switch that has become inoperative and is causing the problem.
...if it is a standard it may be the throw out bearing is no longer allowing the clutch to engage. Do you hear a constant whirring noise when the clutch is not depressed ?
Sorry for your trouble... Hope it is solved without too much fuss.
Carpe Diem
