Sorry to bother you again...got the back up light working with some hot wiring...but discovered that my heated seat switch does work...switched them and the drivers still doesn't work.
Turned on heater without me on seat and it works...pressed down on bottom cushion...goes off.
So, I have a broken wire. Did you actually fix a broken wire rather than replace whole element...which sounds ridiculously involved and I won't do it.
But, if there's a way to get to element, fix it and get seat back together again...in say less than 5 hours...I might be game.
First, is this possible do you know? Will fix last?
Thanks, buddy, really appreciate any advice
