Old 10-16-2007, 04:41 PM   #2
elsabor67
elsabor67's Avatar
Rate My Car: 59 / 246
From experience (just went thru this) I would recommend that you find the same ecu for your car(last numbers 153 or 173). Connect the test ecu and if your rpm's drop to normal, swap your ecu. That was the way I found out mine was bad. Before you do that check your vaccum lines and lines. Good luck.
How do I spell relief??
AUTOBAHNNNNNNNNN
"GO FASTER !!"
