Picture 3: Next remove the stereo. There are two screws on either side of it. Just pull it out and remove the harness in the back. If I recall there is a main harness, the antenna plug, and a smaller plug in the middle of the stereo. This is not seen in the pic.
Picture 4: This is what it looks like with the stereo out. See all those different color wires back there? Those are the wires that you have to run to the drivers side. These include all remote start wires, tachometer wire, trunk pin wire, flashing light wires, brake shutdown wire, and power wires for the alarm.
Picture 5: Now it's time to remove the glove compartment. Look underneath and you will see two tabs like the one in the picture. Remove all four screws.
Picture 6: Next, open the glove compartment. You will see this fabric strand that holds the glove compartment in place. There are two of these—one fabric and one plastic. This is the one of the right of the glove compartment. Remove the small plastic pin with some needle nose pliers. Do the same on the other side.
