Here are the pics of the installation of the Viper 5900 alarm/remote start. Make sure that your have all the proper tools, crimps, tapes, etc prior to starting. It's a bitch when you have to go to the hardware shop in the middle of your project. Also note the these picture where taken when I was putting everything back together, hence, its why everyting is already install. With that said, LETS GET STARTED!
Picture 1: The project car 2001 325ci with 19" Hammon wheels wrapped around michelin pilots. Other goodies include custom fitted audiobahn headrest monitors, custom enclosure with 2 15" Audiobahn flame Qs, Audiobahn a1800dt 1800x1 RMS amp, Audiobahn, a6004t 150x4 RMS amp, audiobahn components, and Audiobahn 2 farad capacitor. Trunk is still a work in progress as well as the stereo. Looking to install an aftermarket navi system, but that another DIY.
Picture 2: Start by removing trim panels. First remove the one above the glove compartment then the one the meets the stereo as seen in the picture. All you need a flat head screwdriver to pop off the trim pieces. You can see the LED was run to the stereo location. When I get to installing my aftermarket stereo, there is unused space in the adapter that I will use to put the LED. JUST FYI.
