Old 10-03-2007, 06:12 PM   #1
dmax
Your Ride: 1999 328i
Back up light...and heated seat
'99 328i E46
Yes, I've checked the bulb, housing, fuse...ain't that.
Passenger side reverse light is out...any liklihood that it's the backup light switch...only putting out enough volts to power the driver's side?
If not, I'll check grounds and then finally the wiring hiding back there.
Also, anyone with knowledge for a heated seat switch repair...the switch is pricey, so if a little solder will do it, I'd love to know.
Thanks folks...
Doug in NJ
