Old 09-24-2007, 01:36 AM   #1
habbie
habbie's Avatar
Title: Forum Sponsor
Rate My Car: 1 / 329
DIY: ** E36 STOCK headlight REMOVAL **
Open your hood and take a look.
Remove the six (6) screws from your hood cowl and also the tubing at the back and pull
up and towards the rear of the engine.
This is what it should look like when you take it off.
Unhook your headlight bulbs.
Take out your turn signal.
Take your 8mm socket and a 19mm wrench and unscrew your headlamps. You will need
the 19mm wrench to hold the back nut in place while your undo the bolts.
The first picture are of the screw under the turn signal, the other is closer to the radiator.
[/color][/b]
